Wanted Bolt in transmission tunnel for 4x4 stick truck and an aluminum transmission inspection cover
Leadfoot
Western Massachusetts
As the title states, looking for a removable transmission tunnel for 4x4 stick truck (preferably from a 205 equipped truck, but not sure if it makes a difference).
Also looking for a K Case aluminum inspection cover (it's for a TH400, but pretty sure a TH350 or 700R4 is the same).
Thanks.
Thanks.
I have the transmission inspection cover.
$40 + shipping
I also have a tunnel cover but I think it's for an auto.
I'll check when I get back home.
Looks like I scrapped the tunnel cover on my last run. Had it sitting in the yard for 3 years and of course 2 months after its gone someone needs it. Good luck with the search.
Bolt in trans tunnel covers vary based on vintage, early 3 bolt per side, late 4 bolt per side. I should have a 78 GMC K2500 tunnel from a SM465/NP205 truck.
The aluminum torque converter covers vary mostly by pan cut out. The smallest is early SBC, biggest is either 6.2 diesel or BBC. For what engine?
BBC
