bolt size / length / grade ?
sweetk30
Back to play nice .
in the back of your brain
my brain is fryed and i just need some info . . .
what bolt size / length / grade for these items ? figure 3/8 thread course just making sure on this .
engine to trans bell bolts
th400 to 203 adaptor grade only using custom spacer .
thanks guys . trying to get budget beater going. she is in the shop on the lift and parts are lining up on the install line.
I can only guess on length but bell housing to engine bolts should be 3/8-16. I think length is 1.25"
I can't tell you for sure, but I think that I used 1.5" long bolts, because I used a hardened flat washer to keep from digging into the trans bell. I would say that grade 5 is probably fine, but I had grade 8, so....
And I don't remember if I used lock washers...
:doah:
Edit: I was referring to the engine to bellhousing bolts.
Dont the 203 adapter bolts use a flanged head with an oring underneath?
I believe they are 1.25" flanged hex head.
I just happened to pull a th350 last Sunday. And:
Bell housing
