Bolt sizes for the front drive shaft please help
bad_bo_ti
OhiO
I need to know the bolt sizes for the front driveshaft. the 10 bolt yoke strap bolts, look like 1/4 inch, and then the np208 flange where the cv joint bolts to. if anyone can help i would appreciate it, thanks, chris
thanks for the reply. i need to get a tap and clean it out then too, its got some mud in it, thanks, again, chris
ok i will try to get some 7/16 and 3/8 bolts and try that. i assume they use lock washer on them or should i just use locktight on them. thanks, chris
transfer case bolts are 3/8ths about 1-1/4", it will stick out some but the is more then enough room, (on a 203 anyway).
hey thanks for the help guys i got everything re threaded just need to get some u-joint straps. thanks again
