OK here is the deal what size bolts is everyone running.
i got the diy front shackle frame hanger.
and 6 inch shackles
and 4 inch shackles
the 4 inch have a 1/2 hole but the stock bolts are smaller a 7/16 i think. so either it fitls the shackle hole or it fits the spring if i pull the sleave out the bushing has play with the larger 1/2 bolt.
on the 6 inch shackles they have 9/16 holes so great they fit the new shackle and shackle hanger (diy) but once again not the spring. i think a 3/4 bolt will work in the spring with out play or a sleave so do i drill out the shackle to a 3/4 and not run a sleave on the spring.
Also if i go that route then when i do the 56 swap i will need the 9/16 hole in the shackle so once again hole size issues.
I was thinking use th 4 inch shackles fro now till swap and drill them out to a 3/4 for the spring and a 9/16 for the shackle hanger (diy) on the frame.
I dont know if im missing something or just doing it the hard way thanks for the help and putting up with the long post.
and 6 inch shackles
and 4 inch shackles
