bolts or studs?
ou8mud2
Banned
Stow, Oh
any pros or cons about using grade 8 bolts or studs in a D60f? in the process of puttin my 60 in and i was told that studs are better.have both available just wanted some opinions.thanks
steve
steve
You have Grade 8 coarse thread?
In high use areas where the thread will be used over and over I like studs. If I had to take my front D60 in an out 5 times a day (:crazy: ) studs would keep the holes from getting worn. I believe that a center section on a 60 is cast steel and will show wear long before the grade 8 bolt loses it's shine!
I have put studs in a front 60 but they where step/repair studs to fix the badly worn taped holes. The previous owner thought he could "pull it" into position with a impact wrench :doah: !
Both coarse and fine bolts/studs can be had in grade 8.
Jeff
