When boring and stroking a motor to get huge cubic inches, what needs to be done in order to make the engine streetable?
I'd like to build an engine for my Highboy (460) into the range of 558 or even 572 cubic inches.
Can a simple cam be used for this? I haven't checked the Comp Cams Extreme 4x4 cams yet but I'd like to build something a little out of the ordinary for this truck.
I'm already aware of block work and preparations in order to clear the crank throws and rod clearance, too. How will cams listed in most parts catalogs like Summit or Jegs perform to larger overbores?
