Bought me a Mall Crawler Today
Boy howdy look at all that room to fit another 50 gallon tank for that thirsty beast!:pimp:
Actually my dads is worn out.. And it still gets 11+ mpg. I bet a more fresh motor could be tuned and get a good bit more
I just had tires balanced & aligned yesterday. What am I looking for multi-piece wise and what would I weld.
Is there something I should be looking for or at on that upper control arm.
This is all new to me so I don't really know what I'm looking at. Tires seem to have normal even wear. all ball joints and tie rod ends seem fine. It does thou at about 35-40MPH have this wheel wobble but goes away over 40 and rolls just fine at freeway speeds. The wobble shows up both acceleration and deceleration at about same speeds
The subframe is the part that spaces the axle and suspension down from the frame. The best kits use subframes that are one piece and not a bunch of separate pieces bolted together.
If it isn't a one piece subframe I'd start to look at the upper control arms and figure out if they were made by Rancho or not. Unless it's a go fast desert set up made by Camburg or somebody upper control arm replacement kits are kind of sketchy on those.
Damn you Cali guys and your stupid clean trucks! Even your brake drums are rust free! :mad:
