I didnt take pics of the wiring mess but the fans had all kinds of resitors, plugs and unused wires from the oem application. About ten minutes of work and it looks factory now.
Next since this will be around water a lot and lots of gear that will be wet and muddy. I decided I liked the look of a gray bedliner. I decided to go with Al's Liner thanks to reading about it on CK5! I also wanted the kids to crawl on it and not damage the wakeboards etc so I would add the rubber crumb to the mix. So these pics explain themselves so Ill give the short tech on it.
1. remove what you dont want lined
2. Clean floor well
3. use 36 grit or coarser everyplace you want liner
4. fill any holes or cracks
5. vacuum Very well
6. clean with Acetone
7. mask off with 3m tape and 3 mils plastic
8. apply liner with chemical mask. Liner has some form of cyanide in it. Follow Als directions
The only "tech" parts I will add is the metal boom or support, whatever I made to hold the plastic up in the middle of the roof. Also came in handy when removing the masking. You have to remove the tape before it dries. This way the ceiling portion wont fall into your wet material.
I also bought a fender for the other shortbed and used the long cardboard to "plug" the window holes.Again single thick cardboard to ease the removal of masking quickly. I used the liner to cover the lower sections of door panels(inside) door sills, and rear inside cargo doors.
All interior lining was done rubber crumb for sound deadening and a more cushy feel when crawling on it.
One more tech item. The sent me 2 gallons of gray and one of tan. Takes over a week to get and since I didnt find out until after every thing was ready. When you get a gallon it has several parts to it plus a pint of color tint. So I went to Lowes and had them mix me some gray to match the parts I already sprayed. They charged me $5.00 for a quart of tint and $3.00 for the can. I sprayed it and it matched perfectly.
Now I want to mix up some blue and not add rubber and spray the blue shortbed lower section! Paint is awesome on that truck but wont be with all the dirt road driving I do. Ill get to that after I can tow the boat with the Bourbon.
