RedBrute
I've thought this over and it seems a reasonable alternate method but perhaps others have tried this and it may be un-doable. In my minds eye this seems simple but I may not be able to describe the idea clearly at first. The idea is to obtain a complete frame from a similar/ exact year truck, remove all brackets. Now take the PASSENGER side frame you just stripped and cut the frame at the cross members. Take those frame sections and place them against the DRIVERS side frame like this [] At that point they could be welded, or for those with no welder/skills, the frame sections could be lap-jointed and then bolted together. The second method may be stronger due to the overlap as well as easier to "undo" , I'm not referring to stacking frames, but overlapping/interlocking frame sections and adding additional steel under the crossmembers if required. I think this would be easy from the front shackles all the way back to the end of the frame at the tailgate. The end result would be a "boxed" or enclosed frame bolted at whatever bolt spacing would yield the maximum holding force with a minimum of holes. It would also be easy to paint all components prior to assembly for corrosion resistance. Does this sound like a good method, or is cutting, grinding, fitting, welding flat stock the the better method?
