BLZN4FN
How did you all box or stiffen your frame? Did you do the whole frame or in sections? Also how thick of steel did you use and anyone have any pics on how it turned out.
38377k5 said:I plan on doing certain parts of the frame and using steel plate similarly sized to the stock frame (1/8" in my case, I think).
cybrfire said:Boxed the whole thing, bumper to bumper. Sections at a time though. 10ga.
INTERCEPTOR said:What parts are you thinking?
cybrfire said:The problem with doing only parts of the frame is the frame will then have the tendency to crack at the end of a boxed section. You'll significantly strengthen one portion of the frame, all the flex will end abruptly right there. Stress riser.
No real need to go with anything heavier than the parent metal. This case being 1/8" or 10ga. (close enough). It's not the thickness your after but the added wall completing the box tube. Now, when you put your crosmembers back in, try to run them completely through the boxed frame.
