A1971Blazer
I looked at the pictures first, then read your comment. I was wondering how you were going to fit all that pipe in your Blazer.
Tube chassis??????
I built the roll cage in my Jeep out of this same 1½" pipe. It's 1-7/8" OD and .135 wall. Bolt-thru plates where it passes thru body metal and welded into the frame in 6 places.
Here's a few shots of it that I dug out of my old archive.
This is at the 2006 "Dixie Run" in Tellico OHV (now closed to OR vehicles)
"Guard Rail Hill" one of the most treacherous obstacles in the entire park.
One of the 4wd magazines included it in the "top 10 OHV trails you could die on" I've seen more than a few rollovers here and a lot of carnage!
See the guy with the camera on the long pole, they were making a video of the event.
I HAD to make it! (There is a drive around)
My son is my spotter......dam good one!
over the top!
All bends made on my "TubeShark" bender. I got a couple of dies with it but they were so expensive to buy more. I just bought the aluminum billets and machined my own.
If I end up building a cage for the Blazer it will brobably be 2" DOM
Sorry these ain't Blazer pics!.........yet.
Everything I've done involved cutoff wheels ,4 1/2 grinder and a Ryobi cheepo cordless drill. If I needed that bend it would of been the vice and a 3lb hammer or cut it then weld it. I do like the simple but effective adjust-ability on that brace.
