braided steel brake line sizing
ryan22re
Irmo, SC
is -4 too big for lines, you know the flexible ones? thats 1/4 inch for those who dont know...
-3 would be 3/16...but i dont have a die to make them up...or any -3 line...
i really cant see it being a problem, other than converting it to the calipers and such.
if you go from a small line to a larger one you lose pressure at the caliper. (i.e a 3/16" from the master to rear then a 1/4" from the 3/16" to the caliper.) you'd need to find some hydraulic formulas to find out exactly how much.
A bigger line is going to move less fluid unless you really increase the MC bore size. The pressure will be less where you need it.
