I don't mind folks throwing out ideas and past experiences. This may be hard to resolve because it's so far very intermittent. Plus, who has time to randomly get stranded? It's not like I drive just to drive and am ok with a dead truck 30 miles from the house.
Anyway...truck stranded me about a month back.
Back story: Truck sat from November to February. First time I drove it again, ran fine for the first 30 minutes. Parked it, let it sit an hour, fired it up, went to drive down the road and it started misfiring. Any time I started to give it gas, it would start bucking like it was starving for fuel. Had an old carb that felt similar. Figured sitting that long perhaps the gas was going bad, so drove straight to nearest station and dumped a few gallons of 92 octane in it. Started driving it, within a few seconds the problem cleared up. Success!
Drove it for about five hours, seemingly ran like a champ. Took a break from driving, started up a few hours later and kept going. Fuel consumption kind of surprised me. Economy had really taken a hit...like 13 instead of 16. Enough that I wondered whether I'd make the next station. Made it to a station, filled up with fuel, and started on my way again. Cruising at 65MPH, less than 15 minutes after filling up, flat ground, check engine light comes on and almost immediately the truck starts to buck, and no matter what I do I can't maintain speed. Luckily there is an offramp right there, and I coast off the freeway. Truck is idling, roughly, but continues to idle. Try to get through the intersection but even letting the clutch out in low/4 low makes it want to stall, and eventually it does. At that point it won't restart. I fiddled around with some connectors just to make sure something I could easily reach wasn't loose, and the check engine only flashed code 12. One oddity I witnessed was that the check engine light seemed to act abnormally at times...such as being dim. But again, seemed random. Disconnect ECM, reconnect, check engine light acted ok. Crank the engine, check engine light comes on, code 12. Repeated a few times.
After I get it towed and stored, I call the tow yard guy a couple weeks later. He mentions they had to move it, and it started right up and moved without issue. Two weeks after that, it started right up again to load on a trailer. Since then it has started and run fine, but only for very short periods of time, I don't trust it enough to drive.
For those not familiar, it's an L31 crate engine, MAF TPI, manual trans. That I think pertinent off the top of my head, the fuel pump is new within the last few years (Delco) so the hose should be ethanol rated. The pickup coil and ignition module are both a few years old, both parts store brands replaced when the OEM pickup coil failed.
I was unable to test the fuel pressure or for spark when it "died". I regret not immediately checking spark.
My first thought is ignition module. Code 12 being set may indicate no pulse from the ignition module. But that's a bit odd since it ran even with the check engine light on, at least for awhile. It seems unlikely to me that anything on the fuel side could be intermittent like this. I can see a bad connector, ground, or wire potentially, but just from sitting, no movement, and then it works like nothing is wrong, seems unlikely.
I can throw parts at it, I've got spares of just about everything, but I hate not knowing whether or not I got the culprit...because then I'm not going to trust it. And I really don't want to have to carry around a crate of spare parts lol. Just figured I'd spew this, and see what others have experienced that may have been similar.
