MEMO43
OK subject is an 83 k5 with crate sbc 350 (35,000miles), 700r4 with np208.
I replaced the booster about 3 months ago. Then noticed a hissing when applying the brakes, as well as shaking while at a stop.
Replaced all vacuum hoses.
Hose to booster
Pcv hose
Heater hoses as well as booster check valve, pcv. Still I get hissing when stepping on the brakes. I'm getting about 15" of vacuum through edelborock 1406 manifold port side at 750 rpms. Timing is at 17 initial 34 total.
I live at 5500 feet but work at 6500 feet.
Daily driver.
I'm on the 3rd booster all from Napa
When I spray carb cleaner around the intake, or any possible vac leak locations I get no change in idle speed.
The base of the carb I get an increase in idle.
Now I know I need to replace the gasket there.
What else can cause my booster to leak air when applying brakes. The sound can be heard underneath the dash when..
I'm almost at a lose here
Any help would be appreciated.
I'm a 911 operator and retired Marine, my next day off will be this mon (memorial day) an Tuesday after that it will be the following weekend.
Where should I start other than the carb gasket
Memo.
Hose to booster
Pcv hose
Daily driver.
Memo.
