I have a '75 blazer I'm putting together. 8 lug dana 44 up front 14 bolt with disc brake swap out back. New SS brake lines from inline tube with their rear disc brake prop valve. I'm at the point where I'm putting the dash and firewall stuff on. The booster from my parts blazer is junk so need some recommendations for parts. I've heard that a 3/4 ton master is an upgrade for a k5. I also heard that the lines are switched for front and rear. Is there anything that would be better than a booster and master cylinder from a 1975 k20? Rather not get into hydro boost at this time.
