Mkuhn138
I just upgraded to Hydroboost. I'm selling my master cylinder, vaccum booster, vacuum canister, and lines - off of an 87 K5 The master cylinder is in great shape, and doesn't leak - it has a fresh coat of paint on it. The booster also has a fresh coat of semi-gloss black on it - I also put the summit brand billet AN hose adapters on it so that you can run -6an hose from it. The vacuum canister is a comp cams canister and will bolt directly into the stock location with a bracket that I fabricated for it. I'm also including the AN hose and fittings - it's aeroquip starlite hose and and red/blue aeroquip fittings. I'm not really sure what going rate for this stuff is, so make me an offer... maybe $200 for everything? I have close to that in the canister and hose.
I will also sell the stock proportioning valve and lines from it to the MC if interested.
