Brake bracket
BLZN4FN
Englewood Colorado
Need brake drop down brakets that come with most lift kits.
Its the bracket the moves the brake line from through the frame
to the bottom of the frame.
Let me know,
Bo
bracket info
i took the factory one off the frame and cut the end off were the rivets go to the frame and drilled a hole in the center section, then re atached to the bump stop bracket . i was running 4" lift and wouldent hit the stops any more and thay had fallen off any way. try this. i havent seen any drop brakets before except for the ebrake lines .
I have some from my lift that are just 90 degree brackets with a large hole on one side for the brake line and a small hole on the other for the bolt. I also have a straight flat one for the rear. I will be able to check on Monday to see if I still have them and get a pic to you. You can have them for free if you want, you just pay shipping.
Hey Bo,
I don't have drop down brackets, but I wish I had a passenger side door :whistle:
Since PM's don't seem to be working :what: maybe just call me? 978-505-1401
-Nick
The angle brackets measure about 1 3/4" x 1 3/4" and the flat one for the rear is 4" long. Let me know if they are what you were looking for.
