Just venting! Truck pulls a little while braking hard so decided to change the calipers (warranty exchange at O'reilly's). Worth a shot I figured.
Nice straight across exchange, bolts right up....then the leak starts at the banjo joint. I tighten, loosen, tighten. Change bolts and washers back old ones. Finally get passenger side sealed up but drivers side just keeps leaking. Try another combination of bolts and washers...still leaks!!
Out of frustration, I go get another caliper and exchange it out. Notice the bleeder valves are all different wrench sizes so get a matching pair (2nd set) of calipers with same bleeder valve size.
Get those new ones one....now passenger is leaking like a sieve! Try and try...still leaks.
Finally, put the first new caliper back on passenger side, tighten, and it stops. Driver's side now is dry too. Bleeders are different sizes but both don't leak. Finally, fixed!
Man that was frustrating! Just needed to vent.
Also tried new pads "Wagner Quiet Stops" because the "Yellow Stuff" pads throw so much dust. Two rounds on the Wagners, and they just didn't do as well as the Yellow Stuff ones. Put the old pads back on and will return the Wagners.
Well, that was a waist of time!!
