Hey guys
So lately after driving my 72 for awhile its seems to be harder to get into 2nd gear so I figured I should go ahead and change the fluid to start off with. Only problem is that I've never messed with bleeding brakes or clutches.
From what i have researched the clutch and brake fluid are pretty much the same thing, would you happen to know of any good videos or links that show how to bleed both the brakes and clutch?
I got a quote from Brakes plus for 39.99 a piece for the clutch and brake flush being that I don't really know what I'm doing, or if anyone may be willing to help out I'd pay for that help as well. I'm in the Denver / Green Valley Ranch area.
It's easy enough to do yourself, if messy and unpleasant. You'll find as many ways to do it as people you ask. After doing manual bleeding (never a helper when I need one), gravity bleeding (boooring), pressure bleeding (did I mention messy?), I find doing it with the hand vacuum pump is relatively tidy, simple, and quick.
