MassMan
Well, it's always something, isn't it? I just got the engine running after a year of headaches and just as i tried to take it for a ride around the yard the brake pedal went to the floor and i had brake fluid all over the frame. The leak is coming from the driver's side of the combo valve, but i can't be sure where. I took it off for a better look but the lines were rusted to the pressure fittings and i snapped the one closest to the leak off and had to cut another with a hack saw. The valve is really beaten up and even if it was just a bad fitting i want to replace it and re-flare the lines.
The first question is where can i get a new combo valve? I checked all the usual online parts stores and all they have is adjustable proportioning valves. Should a local auto parts store have one in stock or available for order?
Also, i've never really done brake stuff before and i'm scared to death of messing something up. anything i should watch out for when flaring the lines and installing everything?
And, finally, a completely unrelated question. The fuel supply hardline rusted out about six inches from the end on top of the tank. I'm planning on cutting all the lines back to the frame cross-member in front of the tank and installing rubber to the tank. Do i need to flare the hard lines like they are from the factory, or will a tight clamp do fine on a straight length of line?
