Brake contoller wont work
ShitownK5er
Shillington Pa
I had this in the Tow and Trailer section, but im in need of quick advise so here it is agian
Ok heres the story i hooked up to my buddys trailer which he wired up wrong and the brake controller stopped working. The contoller came on when the emergency lever was pushed over but thats it. I checked all the fuses(under the hood) theyre fine. So i figured my contoller was bad and that maybe it shorted out. Bought another one hooked it all up and the same thing, its like its not senceing me pushing the brake pedal. Is there a fuse i missed? i have the contoller wired to the factory wire harness that plugs in under the dash. My truck is a 01 k2500 duramax any help would be appriciated its getting real frustrating
hey im havin the same issue on my 03 gm has a tech buliten out on it they reaplce a wire from what in told by the neighbor that sends the sig from the brake switch to the unit hope it helps
