Brake distribution block
MetalMulishaMarcus
1 Ton Status
Disneyland
I've got a 1974 chevy k5 blazer with 1 ton axles under it. I changed out the distribution block for a disk/disk one but found out later that I got a bad one because its leaking.
So I'm in need of a new one but not sure which one to get or what will fit because they all list different size lines.
Here's one I found, will this work? My brake lines are still stock.
https://www.summitracing.com/parts/sum-760186
If any of you know of a better one to get or maybe cheaper please let me know.
not sure . almost looks like it will bolt up like oem .
when i do my next trucks brake system this is the unit i will be doing .
