I haven't put any on my vehicles yet,but a friend who runs a auto repair shop loves the stuff..he does a LOT of brake line replacements every month,goes thru at least two rolls of the 3/16 and 1/4" stuff if not more in that time period..I like it too,and feel its worth the extra $$$ ,especially if your planning on keeping the vehicle,and you don't want to repeat the job ever again..
It flares much easier and is less likely to kink or break when you bend it..he stated his hands would be "dead" after using the double flaring tool to do all the flares on a typical vehicle--often he ends up replacing every line from the master cylinder back on vehicles,because they all have at least one rusty spot that looked risky to leave intact..
The only drawback he has noted with the copper/nickel line is once you torque down the nut fitting,the tubing compresses into the nut and if you try unscrewing it later to replace a wheel cylinder,or other part,it tends to wind up and twist off the line rather than spin freely in the fitting..so you leave a little slack in case it needs to come off someday,and a new nut flared onto it..no big deal,because steel lines rarely ever unscrew after they have been on awhile without doing the same thing..
I bought two rolls of the green coated brake line tubing in 3/16" and 1/4" from a flea market vendor for $14 and $16 each this past year,and used most of the 1/4" roll to replace the long rear brake line on my '81 G-10 van in one piece,my '85 K-10 Burb needs that one done now,it popped last time I moved it..
If I hadn't already bought those rolls,I would have gone for the copper/nickel stuff,the guy started selling that at the flea market not long after I bought the green coated rolls...
In the past I just put those ready made brake lines with the fittings already installed on my vehicles,but they rot thru in so short a time ,I feel its not worth using them--they cost more,and flaring your own lines isn't that hard,but they are "convenient"...I did all the lines on my '82 GMC in late 2011 and they are getting scary looking in places --I have had them pop in less than 2 years before ..(usually in the middle of winter,of course)..
The bulk rolls of tubing are thicker walls and resist rusting better,but even the coated ones rust thru around here in 5 years or so--the copper/nickel ones will likely outlast the vehicle,or the owner..
I say it every time--it should be law that all vehicles should have either copper/nickel or stainless brake,fuel,and transmission cooler lines,especially where road salt is used..I dont see how they get away with using the recycled steel crap they put on at the factory..
