I'm having problems with my brakes being spongy and pulling to the right. My master cylinder and booster are stock 90 blazer, everything else is new Jb7 from a 3/4 ton suburban. With the engine off and the cap off the reservoir brake fluid will squirt out of the chamber closest to the vacuum booster even with light peddle pressure. It will stop at about halfway through the peddle stroke after that the peddle is spongy to about an 1in off the floor. At high speed the blazer will pull hard to the right with light to med peddle persure. At low speed I can push as hard as I can I can lock up the left front. I've tried bleeding a few times I've got a power bleeder on order.
I'm thinking my master cylinder is going out, one of the internal seals has failed.
If my master cylinder has gone out witch one is would be better hydro boost or vacuum boost?
http://m.napaonline.com/Tablet/parts/PartDetails.aspx?Id=NBB501056_0136010790
http://m.napaonline.com/Tablet/parts/PartDetails.aspx?Id=NMAM2414_0358747462
http://m.napaonline.com/Tablet/parts/PartDetails.aspx?Id=NBB527248_0136010786
Thanks for any and all help. Jim
