It's possible if the rubber brake hoses were not new,the old ones are likely hardened up and possibly deteriorating inside--they can plug up solid,or act like a one way check valve--let fluid go TO a caliper or wheel cylinder,then "hold" pressure,like your foot is still applying the brakes,and not let the pedal return..
Last fall I replaced the rear "main" brake line on my '81 G-10 van,the 1/4" line that runs from the front junction to the rear axle's rubber brake hose..
I tried everything,the brakes just refused to bleed,and if I ever got a brake pedal,after frantic pumping,if I stopped pumping the pedal and waited a few seconds,it'd go right to the floor with zero resistance on the next pump!...also no fluid to the rear wheel cylinders...
Thinking the master cylinder was junk from sitting 10 years,(and was "stuck" the first time I tried applying the brakes,and it broke free and loosened up,that led me to think the seals in it ripped,etc,and it could not pump fluid to the rear brakes-- I bought a new master cylinder,and bench bled it-)-only to find it did the same dam thing! .
...then I had the thought to unscrew the new brake line at the rear rubber hose,and fluid came gushing out--so it was getting THAT far.....took off the 2 steel lines on the rubber hose going to the wheel cylinders,zero fluid..!.that rubber hose had actually sealed itself shut inside SO well,125 psi from my air compressor could not blow through it..
I had a used "good" brake hose to swap on in its place--presto--brakes bled perfectly in 5 minutes !..probably the old master cylinder would have "lived"and wasn't junk "yet" ,but I felt a new one for 20 bucks was well worth it for peace of mind..I came close to returning it thinking it too was bad !...
Also-back in the 90's when this van was my daily driver--I had issues with the front calipers failing to release--bought 2 rebuilts and new pads,installed them--next day the front brakes were smoking,still dragging...2 new rubber brake hoses "fixed" it...not the calipers fault!..
