Brake issues with the k30, no problem just broken parts
Cucv_M1008
Cthulhu Forever
Pendleton, Oregon
I was farting around in the yard and I was up on a log and got stuck and I stepped on the brakes hard and lost my peddle, I blead the brake front and rear when I changed it my front calipers, do I need to bleed it more? 84 k30 with a ls swap stock hydro boost brakes.20230427_155229.jpg
That’s a bummer. At least you weren’t getting off the freeway or something. It had to have been damaged at that location somehow.
I think it was rubbing on the shock for along time, I ordered new lines they will be here Monday.
I was farting around in the yard and I was up on a log and got stuck and I stepped on the brakes hard and lost my peddle, I blead the brake front and rear when I changed it my front calipers, do I need to bleed it more? 84 k30 with a ls swap stock hydro boost brakes.View attachment 445355
Brake line sucks, truck is looking good though! :waytogo:
Before you removed the passenger side did you look to see what it was rubbing against? If it was the shock I would think you’d see bare metal where the frayed stainless steel strands wore the paint off. And why is the driver’s side line worn in two spots 90* from each other?
