dasanii19 said:Thanks, Yea I dont know what the guy did before me. Ill inspect the brakes and definitely bleed them and see what happens
imiceman44 said:...the Proportionning valve, it might need to be reset, ...
AZ79K5Project said:What you talking about Willis???? Please expand on this.. What do you mean "reset" the valve?
I don't think you mean hitting it with a BFH...I've tried that and my brakes still don't work
I just did an axle swap, bled the brakes and cannot get brake pressure. It sounded like large amounts of air got into the lines and up into the proportioning valve when the front lines were open during the swap and braided line replacement.
That generally works unless you mess up and let the MC go too low and introduce air from the top....dasanii19 said:Bleeding the brakes is pretty easy right? all I do is pump or step on the brake while another guy cracks the beeder open right?
I think that happened to me when I had the front lifted pretty high during the latest work.AZ79K5Project said:That generally works unless you mess up and let the MC go too low and introduce air from the top....I think that happened to me when I had the front lifted pretty high during the latest work.
When bleeding, start with the right rear, left rear, then right front and then left front. I bought one of those $20.00 hand vacuume pumps a few years back and did a one man brake bleed everytime I've done brakes. It's also not too bad of a way to flush the system.
I'm making a one man bleed pressure system with a tank sprayer and fittings. There are a lot of write-ups on Google and here with different creations.
You look at the hose and you can tell when there is no more bubles coming out then you can start closing them starting from the back working your way to the front.
AZ79K5Project said:start with the right rear, left rear, then right front and then left front.
onetonbb74 said:I could have swore that the rear driver is the farthest from the master cylinder, The main line goes down the passenger side and then hits the rear axle splitter, the longer line off of the rear splitter is the farthest from the master which is driver side.
AZ79K5Project said:I made a pressure bleeder. Cost was about $20.00. I use the compressor set to about 5 to 10 PSI. I got constant pressure at all four wheels and was done in about 10 or 15 minutes from the time I bolted the new MC on.
I added a valve stem to remove excess air from the line.
I used 16 gauge sheet metal for the top. It worked fine. Some people use 1/4 thick metal. I also used a tool box drawer liner as a gasket.
88-383 said:I use a suction bleeder, it has an adapter that attaches to my compressor so it can pull fluid. It works great, but you have to keep the resovoir filled so it doesn't go empty.
KM
