What do all the wires do?
I have power on both sides of the fuses, power to one wire on the front connector, the yellow wire, no power to the white wire when the switch is disconnected. I can't get my probe in deep enough (
) to have it come on when it is connected to the brake switch ( female end probing into the connector)
No power on the back connector which consists of 2 gray wires and on gray with a black stripe but just 2 spades on the switch.
Got a new brake light switch. Both do the same, going out to sharpen my probe (
) to see if I can probe the plug while it is hooked up.
Ideas?
OH the problem is no brake lights, fuse fine bulbs fine, turn signals work
) to have it come on when it is connected to the brake switch ( female end probing into the connector) No power on the back connector which consists of 2 gray wires and on gray with a black stripe but just 2 spades on the switch.
) to see if I can probe the plug while it is hooked up. Ideas?
good luck
