Brake Line Flairs
The question and answers say it will not do steel lines, and the photos only show copper. So I don't think this is what you need.
See, that is why I post here. I used to be able to process stuff like that. I saw in the description "brake" and thought ok. Who uses copper for brake lines?
I have the Eastwood unit, it works great. I don’t recall any issue with leverage, but that was a couple years ago.
There are some copper/nickel lines out there that are softer/easier to flare if you dont want to spend the bucks.
I have had issues with Eastwood air tools. Seems the same as the Amazon I just posted. Video makes it look easy. And he says stainless.
this is the unit I have, and it works a treat. I run a chamfer bit on the end i'm about to flare, then use a few drops of brake fluid as lube. I just did all my brake lines and 3/8" steel fuel lines with it. Get two thumbs up from me!!
