MistaNasty
Registered Member
Recently I installed some extended brake lines and rebuilt my rear drums. Ended up also having to replace a wheel cylinder and both axle seals. Finally got everything back together but I wasn't getting any fluid to the rear brakes. After trying to run air through the lines we could tell there was a blockage somewhere between the proportioning valve and the rear drums. Thanks to some tips on here most people identified the rubber rear brake line as a possible source due to it swelling up. So I took it off and boy were you guys right!
Reminds me of plaque buildup in a coronary artery.
This is my first attempt as a garage mechanic and I must say that despite all the hardships and cussing. IM HOOKED!!!
