Brake line help
crazyhole812
missouri
i need to replumb my brake system. i have an 87 3/4 ton. i got a 14ff rear axle from Boyce with the disc conversion. i guess the master will work but i need to remove the residual valve. do you know where this is? is it in the block at the front crossmember? also do you guys know off hand what size the hard lines are? thanks
