brake line with lift
Braves dude
Registered Member
Delaware
Does anyone gave a part number for front brake hoses once you've put on a 4 inch suspension lift?
Lee
buy the time you guys search / run all over / get longer rubber ones and get o.k. pedal why not just buy the kit and be done with better lines and direct fit. and if you look around there is cheepr places than ord but not by much.
brakes are a major safty item i will not skip out on. :thumb:
My job consists of me having LOTS of time. So after my searching, and running to 1 local parts store, I had new, longer brake lines. To me, OEM is safe. I have better then OK pedal, and I now know if I ever tear one what the part number is. As well as where to find it.
The link posted by British Slave are the lines i went with. They retained the snap ring on the bracket and everything. They are plenty long for my ~5" of lift. And as for the rear, i just moved/lengthened the factory bracket like previously said.
To the OP, I'm 100% sure ORD's lines are nicer and longer lasting. That was just some previous info I found and used. I was quoted 40$ a hose at the local rubber shop and wouldn't do it, so I found this alternative.
