brake lines
burban1500
Registered Member
Lavallette, NJ
im swapping from half ton to a dana 60 and need longer brake lines up front.
do i need anything special or are they both the same?
the banjo bolt size is 10 mm, so if you had a 10bolt, you're fine. If you had a D44, you need the slightly smaller banjo bolt hole
Other than that quirk they are pretty much just normal brake lines. Since you're ordering new, just spec for the truck you got the axle out of and for the lift you have
