brake lines
andyblack
Registered Loser
Grovania, GA
One of the rubber brake lines on my '85 appears to be stopped up pretty bad. I still have the original length lines spaced down with those cheesy little thin metal straps. I don't really want to spend the money right now to get stainless lines. I remember a while back someone on here said something about being able to use stock length brake lines from an '88-'98 two wheel drive Chevy on the earlier model trucks because they had the same fittings and they were 4" or 6" longer than the ones that came on the '73-'87s. Does anyone know if this is true, or am I remembering wrong?
There is a post in the tech articles section called "Post your part numbers". But this I believe is the info your looking for.
Extended brake hoses that are 25 7/8" long will fit 10bolt from 89-2000 2wd chevy/gmc from right front but will work for both sides and can be modified to fit a D44.
Part #'s:
Napa - 38872
Raybestos - 38872
Auto Specialty - HB-86045
Coni-Seal - BH-177767
Carquest - SP8820
Rear extended brake hose Napa part #4138068
