Need to replace the brake master cylinder on my '90 K5 with the 6.2. The parts stores liste 3 different versions:
- w/ F44 heavy duty brake option and under 8,500 GVW
- w/ F44 heavy duty brake option and over 8,500 GVW
- without F44 option
I know the direct replacement would be the last as it does not have the F44 option, but the questions are:
1. Is one of the other options better?
2. Will the others bolt on?
It's a D60 front and 14FF rear with ABS junk removed. All of the above options are within $5 of each other.
