wakeup
Registered Member
Hello everyone, been a long time since I've been on, but in the past I've found this forum to be the best source of info for these trucks. And I'm know my question has been asked and answered before, but the solution to this problem seems to be different for everyone so I'm looking for some input, especially from the folks that have gone through the same thing before.
My truck pulls hard to the right wherever the brakes are applied. So far I've replaced (on both sides) the brake hoses, calipers, slide pins, and pads. This has made no notable difference. I've also replaced both tie Rod ends, rotors, and all four ball joints in the last 10k miles Or less. The only things I can think of now that might be causing this are spring/shackle bushings, the spring pack shifting while braking (but I don't think so) or maybe bump steer (also unlikely since I have the steering corrected well), or maybe something like tow being set to far out.
Any ideas?
Edit: This is an 84 K10 with six inch springs, and a raised steering arm, the steering components are all level.
Any ideas?
