brake question
sunnyc123abc
SoCal
i was just wondering....when going down or up a really steep hill...doesnt the brake fluid go to one side and let air in the lines. if so... wat do you do to correct it for fix it. thanx
You put water in (master cylinders are like radiators, you just top them off with tap water.) As we know, oil floats on water, so this makes sure the brake fluid stays up top above the bubbles.
:eek1: :doah: :haha: :confused: We are kidding, right?
-- A
Dude, go get a dead master cylinder and fill it with dot 3 brake fluid. Then tip it over until the holes in the bottom are no longer submerged. That would have to be like a 80 degree angle, or more with the cap on. I don't run my truck at 80 degrees of angle, does anybody? Plus, we do the little thing that we call, "bleeding" which makes sure that no air is in the brakelines. Seriously, the one system that nobody, especially manufactures, skims on is the brakes. Do you really think they would design a braking system that would fail at simple off-camber angles? Maybe you should just fill it up with water, I hear that compressed air works too. :haha: :haha: :haha:
i know...i know..stupid question, but when i went down a steep hill i lose my braking power and couldn't stop. but when i was flat again it was ok, except that i it felt like there was air in my brake lines,cause there was not much braking power the i depressed it all the way. maybe i was low on fluid.
maby the lid on your master cylinder is craked or broken or missing, and fulid just pored out when you were on a steep hill
