brake rod thru firewall - grommet?
fordsucks!
san diego ca
Hey all, replacing brake booster. Is there supposed to be any kind of a grommet around the brake pedal rod where it goes through the firewall?
Picture attached. Thank you
Yes. Pretty sure the last one I got was from LMC. Make sure you put some lithium grease (or similar) on the rod and or grommet. Mine tore because I didn't.
Thank you. I checked the LMC catalog and found nothing aside from assorted universal grommets. I'll check the other catalogs later tonight.
