Metalhead47
Well this new rig sure is turning out to be more of a project that I was planning for. First the tranny dies a week after I bought it, got that dealt with, now I finally get a chance to pull the wheels off & find out most of the brake system is shot. Found most of the info I need with some forum searches. 1990 3/4 ton Suburban 4x4. Here's what I know is bad and must be replaced:
Master cylinder, rotors, drums, pads, shoes.
While I've got everything pulled apart, here are some might-as-wells I'm going to throw on:
Braided SS lines, manual hubs, wheel cylinders, maybe calipers.
And of course a good thorough fluid flush. Which brings me to my questions. All this carnage was caused by the rear circuit on the MC leaking as far as I can tell, dunno what kind of moisture got into the rear brake lines. Is there any way to flush the lines beyond pushing fresh fluid thru? I'm definitely investing in a pressure bleeder for this job. I plan to go with EBC pads & some drilled/slotted ebay rotors.
While everything is torn apart, anything else I should consider upgrading/replacing? Haven't pulled the rotors yet so I don't know how the bearings are. Any simple master cylinder upgrades for a 3/4 ton? I think hydroboost would be overkill on this rig.
