brake trouble
mwood1985
Marietta Ga
i switched my rubber brake lines out on my 86 jimmy. i was using the c1500 2wd part numbers to extend the lines for the 6 inch lift but i splurged for the superlift extended brake lines. while i had everything apart i tossed new pads and calipers from Advance on just to have new ones in. the rotors were ok so i left them alone and the master and vacccum booster are stock for the 86 model. im having a pronounced braking problem in that if your driving at speeds say above 20 miles an hour and hit the brakes it pulls hard left then right then back left then right until you let off the pedal. kinda like its only got enough force to run one caliper at a time. it pulls hard about a foot or more to the left in the lane then right and ive gotta fight hard to control it. any ideas on what to do to fix it so ive got good brakes again?
