With the engine off and no boost, the pedal should push down a certain distance and then stop.
You should not be able to push it farther. If it does not stop solid, but feels spongy, something is giving.
It is barely possible that one of your soft lines is failing and starting to bulge, but normally it will go ahead and blow out.
Otherwise, you have air in the system. No matter how many times or who did the bleeding.
Hydraulic fluid is noncompressible.
After all the cylinders have moved as far as they can go, you should not be able to push the pedal down any more no matter how hard you try.
If you can, then it is air in the system that is compressing.
There are several bleeder gadgets that might help. A lot of folks have made a pressure bleeder out of a garden sprayer.
The plans are here somewhere I'm sure. The main advantage is volume and time.
You can pour about a gallon or so of fluid in, and bleed continuously for several minutes.
If you have an air bubble sitting at some high point in the system, you put pressure on with the pedal, open a bleeder.
The bubble starts moving downhill pushed by the fluid. Then the master cylinder bottoms out, and you have to stop.
The bubble move back up to where it was.
With the pressure bleeder, it keeps going.
If you put good hard pressure on the pedal, hold it, and it slowly leaks down, you have a bad master cylinder if you do not have an external leak.
It is possible to put such a large set of wheel cylinders on, that the master no longer has enough volume to fill them each time, but its rare.
