1991 3/4 ton 4x4
The brake warning dash light comes on while driving and I can not figure out why? It functions fine when I put the parking brake on and turns off when I realease the parking brake. The problem is that as soon as I hit 35 MPH it comes back on again (and stays on) but a bit dimmer. The 35 MPH speed is pretty consistant too as the light will not come on until I hit that speed. Occasionally at highway speeds it will flicker a bit but typically will stay on until I shut the motor off. This is not an intermitant issue, it happens every time I drive.
Any advise? Could it be the primitive ABS system on these trucks?
thanks,
thanks,
