brake woes...
jimbug
phoenix, AZ
okay so i got the lift on... finally and now my brakes are not there. oh i put a 6" stupidlift on the burb and am trying to convert a new aam 11.5 axle from a new d-max and the disc/drum master cylinder is not doin it. do i need an adjustable proportioning valve and a residual pressure valve... or just the adjustable one? I really need to get my truck back on the road so i can got to work!!:doah: any help would be great:bow:
did you bleed your brakes alot yet?
do a little bit of searching. there should be 2 threads with the info you need that were at the top not long ago.
