I am going to order directly from crown, since black widow is out of business
. I have searched and found...
1982 3/4 ton Jimmy (8-lug 10b and disked 14b
4 lines xx" long 10mm banjo bolt and 3/16" compression fitting
1 line from frame to axle 3/16" compression and a 3/16" tee on the other end to mount to the axle.
I have also read that the front and rear lines from the MC are differant? which is 3/16" and the other???
Thanks is advance!
. I have searched and found...1982 3/4 ton Jimmy (8-lug 10b and disked 14b
)4 lines xx" long 10mm banjo bolt and 3/16" compression fitting
Thanks is advance!
