k20
3/4 ton status
Ok, so its not my problem, friend of mine got an 82 motorhome, based on the g30 van. 350, th400, blah blah blah. Anyway, it had been sitting along time, got it home and it was pretty much out of fluid, brake system looked horrible, etc. Anyway, we replaced all the soft lines, front calipers, pads, rear wheel cylinders, shoes, master cylinder. Did a carb/manifold swap, dual exhaust, then we took it for a drive. Ran great stopped great.
After hes driven it awhile it has gotten to where the brakes will start dragging, then it will pretty much slow to a crawling stop with the brakes smoking. All 4 are locking down. Once you crack open a bleed on the front, it will shoot out a stream of fluid, do one of the rears, and you are ready to rock for a little while, then it will do it again.
We have bled the system a ton of times, replaced the Dot 3 fluid with dot 4 (hoping the fluid was getting too hot, maybe from the new exhaust being close to the brake lines), also replaced the proportioning valve.
Thought we had it fixed, then today it did it again.
I cut the power steering belt off the bastard to see if it did any different (since its hydroboost) and it made no difference.
He warrantied out the new master cylinder thinking maybe that was the problem, no dice, still does it.
We dont really want to buy a new hydroboost if thats not the problem, but thats pretty much the only thing in the system that hasnt been changed and we are at the end of logical thinking with this thing. Does anyone else have any ideas.....please?
