Brakes/ Radiator
90GMCJim
Bay Area
I have been paying attention to my master cylinder and noticed it was low the other day. Found signs of a leak somewhere.
After doing research I seen the c3500 1 ton swap pop up a lot.
No longer available. At this point I have no problem replacing the booster and master cylinder. Any recommendations.
I do have the el dorado rear disc brake setup and 3/4 ton wilwoods in front. Rear semi float and 8 lug swap in front.
On to the radiator I see signs of a big leak around the reservoir. What could be causing this? I added half a gallon of distilled water and today there is nothing inside.
Any help or suggestions would be highly appreciated appreciated. Driving this rig a lot more and the kids like going to local
