WJACKSON11X
I just swapped to a 14bff in the rear. went to bleed the brakes, but on one side, when I open the bleeding screw, nothing comes out. I even removed the screw completely to make sure that it wasnt clogged. If I remove the brake line from the drum, I get a steady flow of fluid, so I know its getting that far. Any suggestions? I still have the factory drum brakes at the moment.
