braking woes
stevewix
hi all, i've got an 85 m1009 cucv that i recently swapped 1 ton axles onto. i thought it braked weird before, swapping the axles confirmed my suspicion, the rear brakes aren't getting any kind of pressure. i can't gravity bleed them, it acts like the line is kinked or the proportioning valve is screwed up. i'm 99% sure they never worked right from day one, so i would rather inspect master cyl, etc.
the rear has a new pro-comp brake line, so the rubber one isn't collapsed or anything.
ideas? questions? post up!
Are the lines kinked?
I had a pain in the ass braking problem and went through 3 masters. I broke off a fitting on the MC and replaced the hardlines to it, and it seems to work fine now on stands
You can try gettin a used master so you can start throwing parts at it, I got them from members for cheap cheap
hey thanks, after bleeding the brakes 4 TIMES then using a suction bleeder i finally got an enourmous air pocket out of the systemworks!
