Brand of Lift...?
JimmyUp
Seattle--Washington
I am looking to go to a 6-inch suspension lift. I have done some looking around at it appears that Skyjacker and Superlift are the only folks that carry front and rear springs for my application.
Are there others that would carry a 6-inch lift for our application? If not, which brand should I go with?
Also, is there any reason to avoid going to a higher lift?
Will my stock driveline lengths be a problem?
Thanks!
Tuff Country does make front and rear springs for your truck. They carry a 6" EZ-Ride spring lift.
I personally went with the Tuff Country 6" EZ-Ride front springs and picked up a 4" shackle flip with a 2" block for the rear. I'm hoping to get rid of the block and put in a 2" spring lift in the future. I went with the block for now to cut down on the cost.
My lift, along with a whole bunch of ORD products are waiting to be installed. I could tell ya how it handles in about a few weeks.
As for the driveline, I'm worried I will have to have my lengthened. I won't know until I throw on the lift. I was told I could get away with a tranny and tcase drop. Does anybody know if that will work?
ak7
On my '72 K/5 I went with Skyjacker Softride 6" springs front and 8" springs rear. <a target="_blank" href=http://communities.msn.com/Ryans1972Blazer/picsofryansblazer.msnw?Page=3>Check out my pic's HERE.</a> I didn't want any blocks in the rear, and i also got rid of the wedge angle shim and torched off the old spring perches and welded new ones on at the correct angle.
You could leave the wedges in there but i've cracked them before and wanted to eliminate that.
I like the skyjacker softrides. I had a 4" lift and 33's and went to the 6"/8" w/ 35's and it felt a lot more top heavy when i first took it for a spin. ( thats with no sway bars) But after a week or two i was used to it.
If you want FLEX, then I'd check out the custom springs that Greg72 just put on his K/5. I know a lot of the first gen guys are thinking about having those custom front springs made now!
