01mudslinger
Registered Member
It is a 88 Gmc Jimmy, Stock 350, 38" TSL's, 10 Bolt Front, Yukon Chromoly 4340's, Lockright, and Standard Warn Hubs.
I put the lockright in the front and ran the stock axles for a while before i broke one, Then i ordered the Chromoly Yukons and put them in. The first trip out i broke a stub shaft right at the splines in the lockout. I had a new one sent and i put them back in and I took out the locker, Been running for months now fine, no broke axles in front, Put locker back in this week and Saturday broke another stub shaft at the splines in the lockout. Wouldnt the axles be stronger than the lockout? What is causing it to break right in the splines of the lockout? My guess is the lockouts are bad and without the locker it was binding and just sent the power to the other axle and with the locker it has no where to go. Any Suggestions? Only thing i know to do is buy New Warn lockouts and give that a try. Please Help
